I am hoping for any advice on a build from OC for a PC that will be used for:-
- Standard home office use
- Photo editing (large RAW files, large volumes) using primarily Adobe Lightroom but also some Photoshop, my primary objective is to make the actual editing run fast and smooth including the AI features. Not so fussed about how long it takes to export batches etc.
- A little gaming but I'm not big into it and tend to play single player so I don't think this will be an issue with the build I'm suggesting but happy to be told I am wrong.
I do want this thing to last a few years, and don't worry about what will likely seem like excessive SSD storage. I do want it
But does the build overall make sense? I have a lot of experience of using PCs but very low knowledge about what actually makes them tick. From what I see using task manager to look at Lightroom the CPU is definitely key for a lot of things and easily maxes out my current CPU, things like AI DeNoise hit the GPU very hard - they are as follows just for reference:-
Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
Palit GeForce RTX 2060 StormX 6144MB GDDR6 PCI-Express Graphics Card
Should I add a little more memory? Is the cooling / power sufficient?
Proposed Build:
OcUK Tech Labs Intel Core Ultra (Arrow Lake) Pro Gaming Configurator
SKU SYS-OCG-00083
Proposed Build:
SKU SYS-OCG-00083
- 1x Lian Li Lancool III RGB Full Tower PC Case - Black
- 1x Intel Core Ultra 9 285K (Arrow Lake) Socket LGA 1851 Processor - Retail
- 1x MSI MAG Z890 TOMAHAWK WIFI (LGA 1851) DDR5 ATX Motherboard
- 1x Corsair Vengeance RGB 64GB (2X32GB) DDR5 PC5-44800C32 6400MHz Dual Channel Kit -
- 1x Lian Li Galahad II LCD SL-INF AIO 360mm Performance ARGB All In One CPU Cooler - Black
- 1x Asus GeForce RTX 5080 TUF Gaming OC 16GB GDDR7 PCI-Express Graphics Card
- 1x Corsair HXi Series HX1200i 80 PLUS Platinum ATX Power Supply
- 1x Samsung 9100 Pro 2TB M.2 2280 PCIe 5.0 x4 NVMe Solid State Drive
- 1x Samsung 990 Pro 4TB M.2 2280 PCI-e 4.0 x4 NVMe 1.3c Solid State Drive
- 1x Samsung 4TB 870 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-77E4T0B/EU)
- 1x Kolink Core Pro Braided Cable Extension Kit 12VHWPR Type 2 - Jet Black/Racing Red
- 1x Build Stock Microsoft Windows 11 Professional - Systems
Any thoughts gratefully received, it's a daunting amount of money to be spending but this thing will be very important to me and get a lot of use . . .
