Photo editing PC Build - £1200(ish) - Help
27 Jul 2015
Hi,
I'm wanting to build a desktop PC that is suited to photo editing.
I've done a rough build list, but was wondering if people had any opinions on what I should get? I did also read that Nvidia Quadro graphics might be better for my needs.
Also, is it going to be worth me waiting until Skylake?
I have £1200 to spend but could stretch to £1400 if needed.
Thanks for any help in advance.
Yeah might as well wait for Skylake, you can get the latest tech then even though there won't be much improvement.
Also no need for a workstation card, something like the GTX 760 will be more than enough.
YOUR BASKET
1 x Asus Maximus VII Ranger - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£15 Saving** £410.94
1 x Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV512HDGL-00000) £299.99
1 x KFA2 GeForce GTX 760 EX OC 2048MB GDDR5 PCI-Express Graphics Card (76NPH6DV8RNZ) £169.99
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED316G2400HC11CDC01) £89.99
1 x SuperFlower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply £62.99
1 x Seagate 2TB SATA-6Gb 7200rpm 64MB (1 Year Warranty) £53.99
1 x Antec VSP5000 Silenced Tower Case - Black £39.95
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £1,162.82 (includes shipping : £12.50 Ex.VAT).
Can easily fit a more expensive case of your choice in as well.
Also you could easily save a few quid by going with a SATA SSD instead or the 256GB version of the M.2 SSD I listed.
YOUR BASKET
1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU) £149.99
1 x Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV256HDGL-00000) £139.99
1 x Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU) £79.99
Total : £379.57 (includes shipping : £8.00 Ex.VAT).
Thank you for your response.
Is the quad core 4790k generally considered better for what I want over say a 6 core i5820k? (Bear in mind I'm not adverse to a bit of overclocking)
Do we have any idea when Skylake will be released for the kind of processor I need? Seems early processors will be mainly quadcore
I've got a spare Samsung PM851 lying around, from a Lenovo laptop. Seems daft not to make use of it, unless Evos are that much better?
August 5th is the release date mate, so not too far away.
Yeah might as well make use of that SSD, will save you a fair bit of dollop!
6 core will be better at Photoshop because it does use all the cores thrown at it. So since you have an SSD already you can easily fit in the 6core 5820k to your budget :)
YOUR BASKET
1 x Asus X99-S - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving*** £524.98
1 x Corsair Vengeance 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (CMK16GX4M4B3000C15) £158.99
1 x Alpenföhn Matterhorn White CPU Cooler £39.95
Total : £1,065.83 (includes shipping : £12.50 Ex.VAT).
I'm telling you this will be absolutely rapid!
I'd probably go with another case now as plenty of money to spare, here are some options for slightly more money.
YOUR BASKET
1 x Phanteks Mini XL Midi Tower Case - Black £144.95
1 x Phanteks Enthoo Evolv ATX Mid Tower Case - Black £139.99
1 x Fractal Design Define R5 Midi Tower Case - White Window £89.99
1 x Phanteks Enthoo Pro Mid Tower Case with Window - Black £89.99
1 x Phanteks Enthoo Pro Mid Tower Case with Window - White £89.99
1 x Phanteks Enthoo Pro Mid Tower Case with Window - Titanium Green £89.99
1 x Fractal Design Define R5 Midi Tower Case - Black Window £88.99
1 x Fractal Design Define R5 Midi Tower Case - White £85.99
1 x Fractal Design Define R5 Midi Tower Case - Titanium Window £83.99
1 x Fractal Design Define R5 Midi Tower Case - Titanium £82.99
1 x Fractal Design Define R5 Midi Tower Case - Black Pearl £76.99
Total : £1,109.75 (includes shipping : £38.25 Ex.VAT).
