Photon 170 D5 or separate?
Most res`s are acrylic.
No reason why you couldn't use that in a 540 :)
Indeed, I've seen it done. But that was modded but I think this would pretty nicely sit on top of the ssd cages.
So can anyone shed light on res sizes. This one seems a little small but does that matter, does res size matter in general?
Res main function is to act as an air trap making bleeding/filling easy.
Only advantage of having a bigger res is water volume the more water the longer it takes for the temps to rise. However I imagine the difference in time is negligible unless res are in the litre+ range. Once the water is saturated size of res makes no difference other than asectics.
