Photoshop and Gaming
19 Feb 2010
Hey all.
I'm looking at buying a new pc. I game, but also in my new business that I've started up, Wall Printing. I'm looking for a pc that can deliver great gaming at 1440p and be able to process high-detailed images in Photoshop. These images are very big files, and I need to upscale them to get the quality high DPI300. What are my best options? I want to spend less than £2000
What sort of system spec do you have right now?
If I remember rightly, Photoshop is largely single-thread dependent, so clock speed is more important than having numerous processing cores.
I would have thought something like a 9600/X/9700X would easily serve as a very healthy baseline to start with.
In fact, I should think the AMD 7000 series CPUs would also be extremely capable for PS as well, e.g. a 7600/7700/X.
Another option to look into is the Intel 245/265 series (Arrow Lake).
I believe they are likely to be stronger where productivity is concerned (good for gaming also).
I know pretty much nothing about Wall Printing, though I would probably start with 32GB of system memory.
RAM prices have recently gone through the roof, so be aware of that. :/
Now is a good time to purchase a GPU. Due to AI and RAM cost increases, prices are due to go up once again in the coming months.
I'm not sure when, but AFAIK, sometime next year. Probably 1st - 2nd quarter.
Speaking of the GPU, depending on what you already have, I'd be considering looking at cards in the 5070/Ti or 9070/XT range for 1440p gaming;
however, you can still get a very good experience indeed with something like a 9060XT 16GB or 5060Ti 16GB.
The 'super' variants of the RTX570/5080 are, last I heard, coming sometime next year, though it could be a while before anything materialises on that front.
Personally, I would buy sooner than later, and I'd recommend something that has 12GB of video memory at the very least, though 16GB would be ideal.
Hope that helps to get the ball rolling. :)
