Sorry to do this but I am so out of date with my knowledge of current hardware. I need to upgrade from my AMD 3700+ shuttle system and have a few specific requirements.
Machine will be used for (in priority order):
- Email internet and all the usual stuff
- Photoshop CS3, usually ~30 images loaded into memory at once
- 1 or possibly 2 VM's when working from home - running enterprise software; IBM MQ, TIBCO EMS, TIBCO Administrator, several databases Oracle, MS SQL etc
- Video editing from digital camcorder in adobe premier pro
- Playing music
- Would like to run a virus scanner (I usually dont as they are too resource hungry)
Must be 64 bit as I would ideally like >4GB ram, probably 8GB (not sure on OS yet but will be MS)
I May consider a server spec machine as I have been tempted by the HP ProLiant ML350 G5 - 2 x Quad-Core Xeon E5420 2.5 GHz with free processor and ram upgrades to 2GB for £1000 leaving me to spend about 300 on disks and some extra ram. However the price of FBDIMM ram is quite high and the fact it only has a PCI Express x8 graphics slot is a worry as Im not sure how it would handle photoshop or video editing?
If anyone has any suggestions on what I should look at buying I'd appreciate it. I don't ideally want to buy overpriced extreme cpu's and I dont think??? I need SLI Crossfire or even the latest and greatest graphics cards to run photoshop slickly (please tell me if I'm wrong) but I would like dependable quality and as much future proofing as you can get with a PC!
Appreciate any assistance
Stuart
- Playing music
Stuart
