Photoshop CS2 Help
8 Dec 2004
Paignton, Devon
Hi, I am trying to cut people out of pictures to put them all together on another background of my choice and i also want to layer text over the top of them, Is there anyway that is easy to remove a person from a picture in photoshop CS2?
Thanks
there is it involves using mask layers , it would take a very long post to do it
my best advice is to get hold of a copy of the dummies guide that will explain it bettern than I can
If the person stands out from the background try the magnetic lasso tool or draw round them with the pen tool then just copy and paste them into new pic or just drag over.
Quick Mask:
Press Q
Paint in all the areas that you want to cut out
Press Q
Press Shift+Ctrl+I
Press Ctrl+J
The item/s you wanted cut out should now be on a new layer.
SiriusB
