- 10 May 2004
- Middlesex
Hey guys,
I've been given a picture in which they want the background to be made white.
Now the focus is pretty bad but they don't really care because it's for a small web image.
The problem is I'm terrible at photoshop. I've used a couple of youtube techniques in the past which have turned out okay (it has been on males with little hair though) but I'm having a problem with the hair in this picture.
I've tried 2 techiques, using quick selection tool, and using the colour dropper to (in theory) change the colour of the background automatically.
The problem I have is that it works fine for everything outside of the portrait but the gaps in the hair are still grey. Nothing I do looks natural.
So, can you guys help out?
It's a bit cheeky but it would be great if someone could do it for me but also if you could explain the best method for doing it.
The pictures:
Original:
http://i.imgur.com/QukG7YN.jpg
My terrible attempt:
http://i.imgur.com/eGugKq0.jpg
Thanks a lot.
The pictures:
Original:
Thanks a lot.
