Photoshop Help
Permabanned
19 Jan 2009
Devon
I want to make this green background
with this logo as the background in the green pic above
How do I do that in photoshop?
Thanks
Sorry, what?
You mean you want to replace the viking ship on the green bit, with the above sheild. Or am I missing the point entirely.
Not sure how well you know Photoshop but a quick summary of the easiest way is:
Layer 1: Create the background of the document by applying the colour you want - in this case colour #136652
Layer 2: Drag or copy/paste your logo
Layer 3: Add any element not to be affected by the logo - i.e. Images of people/text etc.
Then go back to layer 2 and adjust the layer mode in the drop down box and then play with the layer opacity. For example 'Luminosity' at about 8% looks reasonably close but if you use this mode you will also need to use the magic wand to select the white areas of the logo image and cut/mask them.
In Photoshop there's a thousand ways to skin a cat but play with these layer modes for a pretty simple way to achieve what you want.
10/10
thanks
Failing that post up high resolution versions and I'm sure someone here will help.
