Hi there,
I am in the process of installing CS4 and there are a lot of additional software that is installed with it.
Does anyone know of a website that gives a quick rundown of what each one is and does.
Which bits do you usually install or leave out?
Will just installing photoshop suffice or will I be at a disadvantage because of it?
Also, is it me or does photoshop install both a 64bit and a 32bit version at the same time? I'm on Vista HP x64.
Thanks.
Thanks.
