photoshop plugins
Caporegime
18 Oct 2002
West Yorks
ive downloaded noiseninja for photoshop
its told me to place the complete folder (preserving file structure) into the photoshop plugins folder
and then the option to use it will appear in the filter menu.
but it hasnt. what am i doing wrong ?
Have you restarted photoshop? The plugins are loaded upon opening.
If you have then I would try restarting your computer, if that doesnt work then you have the plugin in the wrong place I think.
tried both :(
ive put the latest RAW file converter plugin in the same folder (my Panasonic FZ8 uses a new version of RAW not found in CS3 apparently) and that now works fine
so its the right folder
anybody used noise ninja before ? or maybe this would be better in photography as noise ninja is for removing digital photo noise.
1. Click here to download the self-extracting zip file. (6 megabytes)
2. Remove any previous versions or copies of the Noise Ninja plug-in from the Photoshop Plug-Ins folder.
3. Unzip the downloaded file (by double-clicking on it) and choose the Photoshop Plug-Ins folder as the destination folder for unzipping.
4. Restart Photoshop and open an image. Go to the Filter menu. There should be a submenu labelled "PictureCode", with an item "Noise Ninja". Select it to launch the plug-in.
5. When the plug-in is running, you can access help, preferences, and license information through the menu bar at the top of the plug-in window. A PDF version of the help is available in the "doc" folder.
6. If you have purchased a license go to the plug-in's Noise Ninja menu and select "Install or view license" to unlock the software. You may use the software without a license but it will run in trial mode.
Followed them correctly?
Edit:
