Hi all
Hopefully this will be an easy one for the PS gurus.
I have an image with a transparent background - the image is a square with rounded corners, and it also has a couple of "holes" in the middle (i.e. gaps showing the background through).
I want to create a drop shadow round the edge of the box only - I don't want shadows in the centre of the box (round the "holes") but I get shadows in the centre when adding a drop shadow via an effects layer.
How do I get the shadow on the edges only (using PS CS2).
TIA
Si.
TIA
Si.
