Photoshop Question
16 Oct 2007
UK
Hi all,
When I use the marquee tool, to change a particular area of a layer, I only know how to use the rectangular selection tool.
How would I pick a different shape? Rather than rectangular, I want an obscure straight lined shape
Thanks
You hero! Thanks chief. You have no idea how long i've been using a combination of rectangles and hand drawn lasso.
i'm a knob.
Also you could use the Pen Tool and create virtually any shape including complex curvature. You can then turn this into a selection. This "Path" as it's called, can be saved for use later on, and has many more possibilities than just being turned into a selection.
Unlike the Polygonal Lasso, you can edit each "Anchor" (Each point in the shape) at any time, in any way. Including curvature in several directions. The polygonal tool is unforgiving and you can't go back on yourself. Although it's fine for quick, simple shapes...
