I want to add rounded corners to a rectangle image. Now I imagined that i would draw over the image with a rounded rectangle tool and use some "cut" command but can't seem to do it.
You could use the 'Rectangle Marquee Tool' change the 'Feather' until you've got the corners perfect. Then you can cut, copy to a layer, trim or whatever you like.
Use the rounded rectangle tool, draw over the image, the right click -> make selection. Press CTRL+C and open a new document (CTRL+N) and paste (CTRL+V).
