Now this image, instead of the mom bit, can you replace it with roses around it. or make the mom bit wiped out so its a clear roll, and have roses underneath!
might need to make the edge around it bigger, to look like skin or whatever. to fit roses on.
use the roses from this possible to make them symetrical(spl?) one in center, two to the left, two to the right, the center rose being infront. others in sequence. also if you can make the roses not so washed looking, bit more warmer, darker colours similar to in the photo above.
Big help if you can thankyou.
-Neon.
-Neon.
