Photoshoppers help appeal!
31 May 2006
Hi all you photoshop whizz kids!
Any chance some one can photoshop some Fox R4 17" alloys onto a black MK5 Golf (not Sport, GTi, R32 etc..) just a average MK5 black Golf?
Cheers
I have a folder dedicated to OcUK car photochops. :D
Wouldn't happen to have an image of the wheel on a white background? It's easier to cut out is all.
InvG
btw they are 16 inch if that makes a difference
ta
edit: and the current wheels are 15 inch :p
Well it's certainly not a good job...Oh, and it looks like I slammed some 18"s on :p...in seriousness, I just tried to make it look right, and well, the stock rim on a 306 is 14", no? So the size increase is close to what it might be, but not so bad...plus I 'put on' some slim rubber. ;)
Lost the depth of the rear wheel when sorting it out, which is a shame, front looks ok...but slightly wrong...part of that ofcourse is the no discs etc.
It's after midnight...so you won't get a spanking job tonight...if it were tomorrow morning/day you'd asked, well that's different...
InvG
Cool, Cheers mate thanks for the effort, it does still show kinda what they would look like.....and i like! :D
I would have asked tomorrow morning but here is filtered at work :(
I think ill probably order the wheels tomorrow :D
It does look good, and some wheels on 306s work, others don't, these work. The wheels I saw earlier on a green one worked really well too, I don't know what they were though.
I'm glad you haven't picked a bad set though. :)
InvG
InvG
The time ive spent looking is shocking! i was looking at TSW Heats 17s but I just kept telling myself not to settle until they were right! and i think the decision is good! well we shall see on monday when they are delivered :D
I also went with 16s as i have heard 17s can ruin handling and will also have more of an effect on the speedo reading and acceleration
Heats:
Granted they look alright there but they are the 15 inch ones stretched as i couldnt get a picture of 17s so they look better here than they would in real life... also i think heats have a tendancy to make my brakes look poo...
I will probably create a thread on monday with lots of pics of my new rims if your interested :D
