Photoshopping SFF Help Please
31 Dec 2012
Hi Guys
Hope I'm in the right section - I'm looking at putting together a SFF set up, mostly to run PS5, LR4 and similar with a bit of browsing and the occasional game thrown in.
I have my os, monitor, hdd, odd, keyboard and mouse. Due to space restrictions I would prefer a vesa mount case so I can shove it on the back of the monitor. My budget is £250 tops, so far I've come up with this;
ASRock FM2A75M-ITX AMD A75 Chipset (Socket FM2) DDR3 Mini ITX Motherboard £69.98
Akasa Crypto Vesa Mini-ITX Case with 80W PSU - Black £59.99
AMD A6-5400K Black Edition 3.60GHz (Socket FM2) APU Trinity Dual Core Processor (AD540KOKHJBOX) £49.99
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £39.95
Sub Total : £183.26
Shipping : £9.50
VAT: £38.55
Total : £231.31
Never having done this before I'd like confirmation that all of the above will go together ok :D and any options/changes that you would recommend.
Thanks
YOUR BASKET
1 x AMD A8-5500 3.20GHz (Socket FM2) APU Trinity Quad Core Processor (AD5500OKHJBOX) £77.99
1 x ASRock FM2A75M-ITX AMD A75 Chipset (Socket FM2) DDR3 Mini ITX Motherboard £69.98
1 x In-Win BQ Series 660 Mini ITX Case with 120W PSU - Black £56.99
1 x Adata XPG Xtreme v1.0 8GB (2x4GB) DDR3 PC3-17100C10 2133MHz Dual Channel Kit (AX3U2133XC4G10-2X) £47.99
Total : £264.95 (includes shipping : £10.00).
Will perform a lot better than the A6..
Different Case, simular price. Choice is yours...
Is your ODD a slimline?
Thanks for the quick reply.
Yes, my odd is a slim one.
Couple of questions about your suggestions;
1 would the case need any fans?
2 what is the difference in performance between the RAM you suggested and the one I had? (Honest question as the numbers mean very little to me!)
Awesome times.
The case shouldn't need any fans. Won't get hot enough.
Both the ram you and I soecced are perfect. Both are fast, which helps the apu's igpu. The only real difference is the one I specced is specced profile though it doesn't matter. Whatever is cheapest will be best.
