PHP 5 + MySQL Problem
27 Apr 2004
Not sure this is the right forum but it was my best gues...
I upgraded my server (Windows XP :o ) to the latest version of PHP 5 from PHP 4 today. Reason for doing so is I need some of the functionality for a script I'm making. However I now face the problem that no MySQL based stuff works; so that's two forums and a gallery down. Now of course I've enabled the MySQL extension and set the path right, and I know extensions are working because I've also enabled GD2 and it works perfectly.
The errors I get when trying to use any MySQL functionality basically say function not defined eg.
Code:
Fatal error: Call to undefined function mysql_connect()
What am I doing wrong? MySQL version is 4.1 if that's of any relevence. It always used to work fine with PHP4.
Thanks, null :)
Everything is there, it's just not "on" by default.
You'll need to uncomment the php_mysql.lib file, and the other one (summin like libmysql.so or summat) in your php.ini.
Thanks I've copied libmysql.dll to system32 now. Unfortunately I'm at school and so can't restart Apache 'till I'm home though. Also I did already have extension=php_mysql.dll uncommented.
Thanks, null :)
hang on.... on what PC have u installed PHP....?
It's supposed to go on the same PC as apache....
It is on the same PC but I thought it shouldn't matter anyway :p
Reason I can move files around is I have a web based file manager running on it, so I used that to do what I could earlier ;) Problem is the school proxy server is fine with that but of course kills things like remote desktop. Which I would need to restart Apache.
edit - PHP install does need to be on same PC I know, and it is, misread your post and thought you said MySQL. Both PHP and MySQL are on same server.
And now I've got the script that needed it working; my signature. Reason that PHP4 couldn't cut it is that no matter what I did, I could not access files with a URL; only from disk.
This was a problem because I have to use a URL to get the OcUK FAH stats file from the Stanford server for updates.
/ Randomness :o
