- 2 Nov 2005
Hi all
I've been using Brinkster.com to host the asp sites I've been doing, but I want to learn php and use the same host for both, does anyone know of any good free php and asp hosts? I've been looking here and the top 3 are ZoveNet, GlobalWeb and Zogola, has anyone used these, are they any good or are there others that people think are better?
I also need a good paid for php and asp host for this site if anyone can recommend any that'd be great thanks
What is the difference between php and asp, is one better then the other? As you can see from the Donability site, atm I'm using asp to display the pictures in the gallery, would php be better for this?
I've been looking at the tutorials on tizag.com and noticed two different databases, SQL and MySQL, whats the difference between them, is one better then the other? Does it matter which is used with php and asp? And do both work with Access?
Thanks.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thanks.
