PHP and if commands
13 Nov 2003
Manchester
Hi All
Just working on something, trying to get an if command to work
What I need is a statement that I can drop into the body of my page that does the following things.
If $auth =1 then display some html
if $auth =0 then display nothing.
Im sure this is really easy but im still learning php lol
Thanks in advance you lovely people
Code:
if ($auth == 1) {
//do stuff
} elseif ($auth == 2) {
//do other stuff
One = (=) is the assignment operator, and two = (==) is the comparison operator :)
Spot on, cheers dude.
Now, this is slightly annoying im sure lol... but how do I put html within that, probably a table.
As I know html within php is a bit wierd lol
Thanks
Aaron
No it's not :p
You can either echo it:
Code:
<?php
if ($auth == 1)
    echo '<table>';
    echo '    <tr>';
    echo '        <td>text</td>';
    echo '    </tr>';
    echo '    <tr>';
    echo '    </tr>';
    echo '    <tr>';
    echo '    </tr>';
    echo '</table>';
...or you can embed it:
Code:
<?php
if ($auth == 1)
<table>
    <tr>
        <td>text</td>
        <td>text</td>
        <td>text</td>
    </tr>
    <tr>
        <td>text</td>
        <td>text</td>
        <td>text</td>
    </tr>
    <tr>
        <td>text</td>
        <td>text</td>
        <td>text</td>
    </tr>
</table>
<?php
or heredoc:
Code:
echo <<<LOL
		<div class="64">
			<p>When I get older</p>
			<p>loosing my hair</p>
			<p>many years from now..</p>
		</div>
LOL;
Dj_Jestar said:
or heredoc:
Code:
echo <<<LOL
		<div class="64">
		</div>
LOL;
I like heredoc apart from the fact that the end bit can't be indented, which kind of messes things up if you're a couple of blocks indented.
I find it really nice for generating RSS though, since you can populate some variables at the top and then heredoc the rest :cool:
