php array unique
19 Jul 2006
Looking for a bit of help,
I have created a function that will return an associative array though I could change this if it would be better.
output is something like
PHP:
Array ( [0] => 123ABCStreet [1] => 123ABCStreet [2] => 321CBAStreet )
I then need to do something like this
for values that are unique {
return $unique key
for duplicates {
return $duplicates key
any pointers in the right direction.
I suggest that maybe you can have a look at:
foreach( $yourAssocArray as $key => $value) {}
array_push(), in_array()
which could help you to create a few arrays which contain unique and duplicate keys/values.
foreach($array as $key => $value):
if(isset($unique[$key])):
$unique[$key] = $value;
else:
$duplicate[$key] = $value;
endif;
endforeach;
Fairly similar to suggested above.
