PHP Arrays - help going Multidimensional
18 Oct 2002
Somerset
I have being doing some work in php and have several arrays created that i now want group together inside another array,
I have read over several tutorials and articles on multidimensional arrays but i am not getting very far with it.
lets say i have 3 arrays
$array1
$array2
$array3
each of these arrays has 10 keys numbered 100, 90, 80 etc etc (they hold percentage details so that was a easy numbering system to use)
now i have these 3 arrays i want to group them into
$arrygroup
Can this be done after the first 3 are created and populated, or will it have to be done at the start and i need to alter everything else to point to the array in an array?
and will i get
$arraygroup[1] pointing to and returning the array $array1 etc etc.
If so how do i then 'get to' $array1[80] from inside $arraygroup ?
Is it anything like $arraygroup[1[80]] or am i waaaaay of the mark?
Thanks
Try this:
Code:
$array1 = array('foo1', 'bar1');
$array2 = array('foo2', 'bar2');
$array3 = array('foo3', 'bar3');
$arraygroup = array($array1, $array2, $array3);
// Outputs: foo1
echo $arraygroup[0][0];
// Outputs: bar3
echo $arraygroup[2][1];
Note any modifications to $array1, $array2 or $array3 after they've been added to $arraygroup will not be reflected in $arraygroup.
Alternatively you can add elements individually:
Code:
// Add the elements sequentially.
$arraygroup[] = $array1;
$arraygroup[] = $array2;
$arraygroup[] = $array3;
// Or add the elements with explicit keys.
$arraygroup[0] = $array1;
$arraygroup[1] = $array2;
$arraygroup[2] = $array3;
These all do the same thing.
Just remember that arrays are naturally zero-based in PHP.
Thanks Inquisitor,
After posting i went back and had a look at it again, got some where with it, and then stumbled upon how to make it work as i wanted, better than originally planned, which has in fact made the next step much easier.
Method isnt a million miles from your first example, but i have now ditched $array1 2 3 and gone straight into the multidimensional array and everything is now accessing $arraygroup which has now also allowed me to use a number where before i could not which can be +1 'd later in a while loop, solving another problem.
If that makes sense.
