php form submission help
Permabanned
22 Apr 2007
Ok, so not a mailing list but something easier perhaps?
I want to make a form then php comes a long and submits the form to an email address. It also writes some of the fields to a file none of which can be seen by the user, however, when they click on submit, they then get redirected to a 'thank you' style page.
Any hints?
I've recently been trying to do a similar thing.
I'm a PHP noob so can't really help with anything in depth, but here's the code from the php script to send the e-mail...
Code:
<?php
//--------------------------Set these paramaters--------------------------
// Subject of email sent to you.
$subject = 'Results from Contact form';
// Your email address. This is where the form information will be sent.
$emailadd = '[email protected]';
// Where to redirect after form is processed.
$url = 'http://www.website.com/thanks.html';
// Makes all fields required. If set to '1' no field can not be empty. If set to '0' any or all fields can be empty.
$req = '0';
// --------------------------Do not edit below this line--------------------------
$text = "Results from form:\n\n";
$space = ' ';
$line = '
foreach ($_POST as $key => $value)
if ($req == '1')
if ($value == '')
{echo "$key is empty";die;}
$j = strlen($key);
if ($j >= 20)
{echo "Name of form element $key cannot be longer than 20 characters";die;}
$j = 20 - $j;
for ($i = 1; $i <= $j; $i++)
{$space .= ' ';}
$value = str_replace('\n', "$line", $value);
$conc = "{$key}:$space{$value}$line";
$text .= $conc;
$space = ' ';
mail($emailadd, $subject, $text, 'From: '.$emailadd.'');
echo '<META HTTP-EQUIV=Refresh CONTENT="0; URL='.$url.'">';
Pretty straight forward and a good starting point. If you have knowledge of PHP, you should be able to amend it to suit.
