PHP Help URL Encode
18 Oct 2002
Hi
I've setup a database of manufacturers to search for by a dropdown
When the value is selected hit the search button & brings back results etc
Manufacturers are stored as varchar in MYSQL
eg manufacturers are
BMW
Aston Martin
Volvo
When you select & search for BMW the results don't come back as
myurlt/search1.php?Manufacturer=BMW%22&Submit=Search
%22 seams to be a url encode issue & doesn't bring back any results
Should be
myurlt/search1.php?Manufacturer=BMW&Submit=Search
Now a 2 part name (i.e. Aston Martin) only picks up the first part
myurlt/search1.php?Manufacturer=ASTON&Submit=Search
but brings back the results ok but it would be nice to get it to enter as
ASTON+MARTIN
PHP:
<?php
function menu( $_nam )
    $_sel = '<form name="form" action="search1.php" method="get"><select name="'. $_nam .'">';
    $_sel .= '<option selected>Manufacturers</option>';
    $_qry = mysql_query("Select distinct Manufacturer From t21 Where Manufacturer > '120' Order By Manufacturer Asc");
		    while ($_dat = mysql_fetch_array( $_qry )) {
        $_sel .='<option value='.strtoupper($_dat['Manufacturer']).'">'.strtoupper($_dat['Manufacturer']).'</option>' ."";
    $_sel .= '</select><input type=Submit name=Submit value=Search onSubmit=value></form>';
    return($_sel);
 echo menu('Manufacturer');
Anyone know where i'm going wrong?
Thanks in advance
%22 is a double quote (").
You haven't put quotes around your variable names except for in one case, which is why it's sending that double quote as part of the value.
Look carefully:
Wrong:
Code:
Right:
Code:
$_sel .='<option value='.strtoupper($_dat['Manufacturer']).'>'.strtoupper($_dat['Manufacturer']).'</option>';
Edit: As for part two, use urlencode() around any values. So instead of value=[an uppercase version, which may fail due to case sensitivity anyway], you have.... value=[aha, a urlencoded web-friendly version].
Code:
$_sel .='<option value='.urlencode($_dat['Manufacturer']).'>'.strtoupper($_dat['Manufacturer']).'</option>';
Ok working now but I've changed the urlencode to urldecode as split words weren't working correctly Aston Martin became Aston%2BMartin instead of Aston+Martin
urldecode returns only the first part of the words Aston in the search
Code:
$_sel .='<option value='.urldecode($_dat['Manufacturer']).'>'.strtoupper($_dat['Manufacturer']).'</option>';
I'm I missing something here?
Code:
<?php
    $_sel = '<form name="form" action="data_search.php" method="get"><select name="'. $_nam .'">';
    $_sel .= '<option selected>Search by Manufacturer</option>';
$_sel .='<option value='.urldecode($_dat['Manufacturer']).'>'.$_dat['Manufacturer'].'</option>';
    $_sel .= '</select><input type="Submit" name="Submit" value="Search" onclick="value"><input type="reset" value="Reset" name="reset"></form>';
    return($_sel);
I meant the one that handles the input from that form :)
urlencode() will turn "Aston Martin" to "Aston+Martin" so I'm wondering what you're doing with the query :)
Beansprout,
I haven't made an input form as yet, only the dropdown
I've tried urlencode & the url changes to aston%2bmartin which is a + but doesn't find any results
urldecode changes to aston (without martin) but does bring back results for aston but isn't accurate
