PHP - help with recursion
19 Jun 2003
West Yorks, UK
Hi folks,
I think this is an easy one, but its the first time I have attempted recursion.
I have a MySQL table that stores items for a menu. It has the following fields:
- id
- depth
- left_id
- right_id
- title
So I have entered the data (manually at the moment, but will be automated eventually), and they look like this when selected into an array:
Code:
Array
    [0] => Array
            [id] => 1
            [depth] => 0
            [left_id] => 0
            [right_id] => 2
            [title] => Home
    [1] => Array
            [id] => 2
            [depth] => 0
            [left_id] => 1
            [right_id] => 4
            [title] => News
    [2] => Array
            [id] => 4
            [depth] => 1
            [left_id] => 2
            [right_id] => 5
            [title] => Archive
    [3] => Array
            [id] => 5
            [depth] => 2
            [left_id] => 4
            [right_id] => 3
            [title] => Really old stuff
    [4] => Array
            [id] => 3
            [depth] => 0
            [left_id] => 5
            [right_id] => 0
            [title] => Contact us
This should produce a menu structure of:
Code:
- Home
- News
-- Archive
--- Really old stuff
- Contact us
Can anyone create a simple recursive function to generate that structure from the above array?
Cheers,
Matt
I'm not sure the whole left_id, right_id thing is the correct way to go about it? Why not try having a parent / child thing going on?
Code:
<?php
function ArrayDepthList ($array, $indent = 0, $spacer = '-')
    $output = '';
    $spacerOut = '';
    for ($i = 0; $i < $indent; $i++) {
        $spacerOut .= $spacer;
    foreach ($array as $arr) {
        if (is_array($arr)) {
            $output .= ArrayDepthList($arr, $indent + 1, $spacer);
        } else {
            $output .= $spacerOut . $arr . "\n";
    return $output;
echo ArrayDepthList(array(1,1,1,array(2,2,2,2,array(3,3,3,3),2,2,2),1,1,1));
Will give you something to work with.
Yeah, im not sure it offers anything either to be honest - was something new I was trying. However, I don't see that having a parent_id offers me a great advantage though to be honest. The problem is that when iterating through the array, it doesn't know whether an ID has children or not. It goes something like this:
- look at item
- add to array
- move to next item
- does item have a parent?
- if yes - Damn, go back a step and add it to the children list!
- if no - Move onto the next
I wonder if I would be better doing the sorting from the end of the array and working upwards? That way, I would know if an item had a parent, so could pass its ID onto the next iteration of the loop to be attached to its parent.
Blimey this hurts my head :S
DJ_Jestar - thanks for the code. The problem is, your array is already sorted into a parent/children relationship - thats the stage I am trying to get to.
Cheers,
Matt
Why not just extract it from the DB in the correct order? Ie, ORDER BY left_id ASC. Then when you're looping through your result set, use depth to determine how to pad it. I certainly can't see the need for right_id in addition to left_id.
A simple structure for this menu...
- Home
- News
-- Archive
- Contact us
... would be:
Code:
Name		Order	Depth
Home		1	0
News		2	0
Archive		3	1
Really old...	4	2
Contact Us	5	0
The query to get the stuff out in order:
Code:
SELECT Name, Order, Depth
FROM TableName
ORDER BY [Order]
And the PHP to output it all:
Code:
$PadString = "»";
$Output = "";
for ($i == 0; $i < Len($Results); $i++)
	for ($x == 0; $x < $Results[$i]["Depth"]; $x++)
		$Output .= $PadString;
	$Output .= $Results[$i]["Name"]."<br />\n";
Probably simpler to maintain than trying to keep left_id and right_id in sync. As jamesrw suggested, parent + child stuff would be the *better* way to do it, but would mean recursive coding, which can be a lot of extra effort.
Note the code is off the top of my head, so most will contain errors. :P
What sort of table structure would you suggest for a parent/child menu then? I think this left_id and depth stuff is heading in the wrong direction.
Any suggestions?
Matt
in the past i've had a table structure of
menu_name | Parent
For menu items at the top level you set it to a parent of 0
then for any sub menu items you give it the id of its parent.
But I think I used this for a 2 level menu system but I dont see why it can't handle multiple parent levels
In that case, daz hit the nail on the head.. Iterative loop..
Code:
<?php
$array = Array
    Array
            'id' => 1,
            'depth' => 0,
            'left_id' => 0,
            'right_id' => 2,
            'title' => 'Home',
    Array
            'id' => 2,
            'depth' => 0,
            'left_id' => 1,
            'right_id' => 4,
            'title' => 'News',
    Array
            'id' => 4,
            'depth' => 1,
            'left_id' => 2,
            'right_id' => 5,
            'title' => 'Archive',
    Array
            'id' => 5,
            'depth' => 2,
            'left_id' => 4,
            'right_id' => 3,
            'title' => 'Really old stuff',
    Array
            'id' => 3,
            'depth' => 0,
            'left_id' => 5,
            'right_id' => 0,
            'title' => 'Contact us',
    $spacer = '-';
    $spaceOut = $spacer;
    for ($i = 0; $i < $arr['depth']; $i++) {
        $spaceOut .= $spacer;
    echo $spaceOut . $arr['title'] . "\n";
outputs:
Code:
>E:\PHP\php.exe -q test2.php
-Home
-News
--Archive
---Really old stuff
-Contact us
>Exit code: 0    Time: 0.325
Thanks again - that is great, but I need them in an array which is what is causing me such trouble. E.g., I need this as my output, which I don't think is doable with your code:
Code:
array(
	[0] = array(	"id"	=> "1",
			"title" => "Home",
			"depth" => "0",
			"parent"=> "0");
	[1] = array(	"id"	=> "2",
			"title" => "News",
			"depth" => "0",
			"parent"=> "0",
			"children" =>
				[2] = array(	"id"	=> "3",
						"title" => "Archive",
						"depth" => "1",
						"parent"=> "2");
