PHP Help
4 May 2003
Guys.
I have a database table that contains a field, lets call it x. The field x contains a n ip address number.
I wish to retrieve this and analyse only the first octet.
For instance in the IP 192.168.0.1 I only want to analyse the 192 part. I have been using the PHP command split to do this. This I believe splits each IP address into an array containing four values (one for each octet).
I have the following sql select statement.
select x from table_name;
I then use mysql_fetch_array to retrieve the IP address values.
This is where I get stuck.
I have two more variables $y and $z which are integers, I wish to evaluate each value I retrieved from the select statement to see if it is greater that 65. If it is greater than 65 I wish $y to increase by one and if it is less that 65 I wish $z to increase by one.
Does Anyone have any pointers? I am pulling my hair out here :D
Thank You In Advance
If I understand you correctly, which i'm not to sure I do :s
PHP:
<?php
$y = row['y'];
$z = row['z'];
if ($y > 65 | $z > 65) {
$y++;
} else {
$z++;
// now just update the database.
Code:
// Perform query and get IP address(s)
// Get individual octets
$octets = explode(".", $ip);
foreach ($ip_octets as $octet)
	if ($octet > 65)
		$y++;
	if ($octet < 65)
		$z++;
Iquisitor, your's will analyse all four octets, the OP only wants to look at the 192 part (first octet) :)
Code:
<?php
$oct = intval(subtstr($ip, 0, strpos('.'));
if ($oct > 65) {
    $y++;
} else {
    $z++;
btw - what do you want done if the first octet == 65? :)
:p
If you have a variable $ip, then the following line will increment $y if the first octet is >65, and increment $z otherwise.
Code:
intval(substr($ip, 0, strpos($ip, '.'))) > 65 ? $y++ : $z++;
Since you're getting the variable out of a database, chances are that the variable is in something like $row['ip'], instead, so you'll need to allocate that to $ip first.
If you just post your code, we can sort it out in about 2 minutes :)
Code:
Since you're getting the row out of a database, chances are that the variable is in something like $row['ip'], instead, so you'll need to allocate that to $ip first.
My Code Is As Follows:
Code:
Code To Connect To Database;
$sql = select x from table;
$result = mysql_query($sql);
$ip_address = mysql_fetch_array($result);
Thats As Far As I can get, I now need to enter the code to split the IP address so I only look at the first octet and then the code to increment $y or $z.
Code:
while ($ip_address = mysql_fetch_array($result)) {
$octet = intval(substr($ip_address['x'], 0, strpos($ip_address['x'],'.')));
$y = 1;
$z = 100;
if ($octet > 65) {
    $y++;
} else {
    $z++;
or using the explode function that you said you were using earlier
Code:
$octet = explode('.', $ip_address['x']);
$y = 1;
$z = 100;
if ($octet[0] > 65) {
    $y++;
} else {
    $z++;
