Hi again guys Im in a bit of a pickle.
I have this code here.
now that outputs this.
lovley
Obviously the buttons don't pass the correct value to the next php file as they take what ever the last value of the barcode was from the last item hence all buttons lead to the same bit of information.
how can I get them sending the correct bit of information for each item?
Thanks in advance
Edd
Code:
$nrows = mysqli_num_rows($result);
for ($i=1; $i <= $nrows; $i++)
$row = mysqli_fetch_assoc($result);
foreach ($labels as $field => $label)
if ($field == 'Barcode' or $field == 'Make' or $field == 'Model' or $field == 'SerialNo')
echo "<td>", $row[$field], "</td>";
echo "<form action = 'Results_item.php' method= 'POST'>";
echo "<Input type = 'hidden' name = 'Barcode' value = '$row[Barcode]'>";
echo "<td colspan = '1' style = 'text-align: right'>
<Input type = 'submit' value = 'View Item'>";
echo "<tr><td colspan = '10'><hr /></td></tr>";
echo "</table>\n";
lovley
Thanks in advance
Edd
