PHP Help
  • Thread starter Thread starter Dup
  • Start date Start date
Dup
Dup
10 Mar 2006
East Lancs
Right, so I'm a front end dev and don't really dabble in much else (yet).
Basically I'm using CMSMS and the LISE/Listit module. Sadly the module has a terrible search so I'm writing a plugin that will query the modules tables and pull back what I need back into the template (Smarty). This means the user can still use the modules admin which is nice and easy to use and I'm displaying the
I have somehow managed to make it work despite limited experience, despite one issues where I'm now stuck and would like some help please.
The search is explicit in that the categories (makes) and titles (models) are pulled into the search form dynamically so there's no free-form user input there and no guessing as such.
The problem is it pulls through all the data fine and spits it out, but if you search 'any' for the category (make) it doesn't pull through a name as it's not being searched against. I now it would never work as I have done it, but I'm not sure how I would go about making it work.
The problem is there's a table for the items, table for the categories (makes) and a table that says what items are in each category. Code and tables below:
PHP:
function smarty_cms_function_vehicles($params, &$smarty) {
	# Get parameters of the search
	$search_parameters = [];
	if (!empty($_GET) || isset($params)) {
		$parameters = $params;
		if (!empty($_GET)) { # URL Parameters or search form submitted via GET (default)
			$search_parameters = $_GET;
		} else if (!empty($parameters)) { # Directly called
			$search_parameters = $parameters;
		# Assign incoming values to search chunks
		foreach ($search_parameters as $key => $value) {
			if (is_array($value)) {
				$value = implode(',', $value);
			} else {
				$value = ($value == 'any' || $value == 'Select Model') ? '' : $value;
			$search_chunks[$key] = $value;
			$make = $search_chunks['make'];
			$model = $search_chunks['model'];
	if (!function_exists('getMake')) {
		function getMake($make) {
			# Get make
			$db     = cmsms()->GetDb();
			$sql    = "SELECT * FROM cms_module_lisevehicles_category WHERE category_name=? LIMIT 1";
			$result = $db->Execute($sql, [
				$make
			$row = $result->FetchRow();
			$make = $row['category_id'];
			$makeName = $row['category_name'];
			return array($make, $makeName);
	$makes = getMake($make);
	$make = $makes[0];
	$makeName = $makes[1];
	if (!function_exists('getIds')) {
		function getIds($make) {
			$ids = [];
			# Get ids
			$sql    = "SELECT item_id FROM cms_module_lisevehicles_item_categories WHERE category_id=?";
				$make
			while($row = $result->FetchRow()) {
				$id  = $row['item_id'];
				$ids[] = $id;
			return $ids;
	$test = getIds($make);
	$ids = implode(',',array_map('intval',$test));
	if (!function_exists('getVehicles')) {
		function getVehicles($ids,$model,$makeName) {
			$vehicles = [];
			# Get vehicles
			if (empty($ids) && empty($model)) {
				$sql    = "SELECT * FROM cms_module_lisevehicles_item";
				$result = $db->Execute($sql);
			} else if (empty($model)) {
				$sql    = "SELECT * FROM cms_module_lisevehicles_item WHERE item_id IN($ids)";
			} else if (!empty($model)) {
  			$sql    = "SELECT * FROM cms_module_lisevehicles_item WHERE item_id IN($ids) AND title=?";
					$model
				$vehicle = new stdClass();
				$vehicle->make    = $makeName;
				$vehicle->model   = $row['title'];
				$vehicles[] = $vehicle;
			return $vehicles;
	$vehicles = getVehicles($ids,$model,$makeName);
	$smarty->assign('vehicles', $vehicles);
cms_module_lisevehicles_item_categories:
cms_module_lisevehicles_category:
cms_module_lisevehicles_item:
Any help would be greatly appreciated. I'm sure it could be done better and my logics probably all wrong. Any insight on making it better and cleaner would be amazing <3
Firstly i'd look at joining (http://dev.mysql.com/doc/refman/5.7/en/join.html) tables as it'd make a lot of that code (potentially) redundant.
Secondly, you want to dynamically build the query (i'm assuming the form input is from static dropdowns).
So if 'make' is only specified then join the tables and search on the 'make' (use category_name column); if 'model' is only specified then string search (in your case i'm guessing) for the model (no need to join any table from what i can see); if both are specified then stick both sections together; if none/'any' then just do a vanilla SELECT.
Thirdly, i'd be sanitising (look at filter_var or comparing returned filter inputs against a known list etc) the form data regardless of any sanitising that's done within the CMSMS database class.
Lastly, i'm slightly confused why you need to iterate through the $_GET response (and the following loop) but then again this is only looking at what you've posted and i don't know CMSMS/it's structure etc.
That's mega mega helpful, thank you! I really appreciate it :)
I've had a brief look and joining tables and that seems like the wya forward. I will get stuck in tomorrow (this) evening.
Cheers for the tip on santising. Should protect it from sillyness!
Yes the loop is not necessary. I started off looking at a completely unrelated plugin to see how it was structured. They had a loop that was checking for POST, GET etc and I lazily just half left it in there in my haste to make progress.
CMSMS can sent paramters to the function.
Right now it's calling {vehicles} however I could say {vehicles pagelimit=10} and then use that to only show 10 results and add in pagination. Not sure if I'm going to bother with that yet, not sure it's necessary as there won't be that many results (in theory) but it would be a nice learning exercise.
Can't wait to give this a go tomorrow, thanks again :)
Excellent, that's the basic search sorted. Much better! Thank you :)
Not sure the if statement is the way to go. Could it be done only writing one query using case? Had a look to see if I could use case to see if $make was null/emptry then select all but not sure that's how it can work. Any ideas or am I barking up the wrong tree.
You'll have to excuse me I'm not progmatically minded, not done enough of it to make sense of what I'm reading online at times!
PHP:
	if (!empty($_GET)){
			} else {
				$value = ($value == 'any' || $value == 'Any Model') ? '' : $value;
		function getVehicles($make, $model) {
			$vehicles = [];
			# Get vehicles
			if (empty($make) && empty($model)) {
				$sql    = "SELECT *
				FROM cms_module_lisevehicles_item a
				JOIN cms_module_lisevehicles_item_categories b ON a.item_id = b.item_id
				JOIN cms_module_lisevehicles_category c ON b.category_id = c.category_id";
				$sql    = "SELECT *
				WHERE c.category_name = ?";
					$make
				$sql    = "SELECT *
				WHERE c.category_name = ? AND a.title = ?";
					$make,
					$model
				$vehicle->make    = $row['category_name'];
			return $vehicles;
	$vehicles = getVehicles($make,$model);
	echo "<pre>";
	print_r(array_values($vehicles));
	echo "</pre>";
Documentation on CMSMS is a little thin but using the qstr() function (not ideal; proper binding with type would be better), which supposedly sanitises variables (i'd still add something yourself), you could minimise the function slightly by building the query as you check the make/model variables, along the lines of -
Code:
// Default Query
$sql = 'SELECT * FROM cms_module_lisevehicles_item a JOIN cms_module_lisevehicles_item_categories b ON a.item_id = b.item_id JOIN cms_module_lisevehicles_category c ON b.category_id = c.category_id';
} else {
    $sql .= ' WHERE ';
    if (!empty($make)) {
        $sql .= 'c.category_name = "'.$db->qstr($make).'"';
        if (!empty($make)) $sql .= ' AND ';
        $sql .= 'a.title = "'.$db->qstr($model).'"';
Also it worth only selecting the columns you need rather than all of them as it potentially helps with performance and security etc.
Also, if there's a fetchAll() function which i've seen mentioned a few times, and assuming it's similar to PDO, then you could use column aliases within the query and scrap the need for iterating through each row and inserting to an array as fetchAll() would return an associative array.
The form data could be retrieved by doing something like -
Code:
$make = ((str)$_GET['make'] === 'any') ? '' : (str)$_GET['make'];
$make = ((str)$_GET['model'] === 'Any Model') ? '' : (str)$_GET['model'];
And as you mentioned, it's worth adding pagination and limiting the returned results.
However, if what you've got works then it's worth sticking with it and doing code refactoring at the end once everything is working correctly.
Thanks for your help. I finally made some progress on this after caring my my dying father this passed few months.
I have almost got it where I want it:
PHP:
<?php
	$details = isset($params['details']) ? $params['details'] : false;
	$limit   = $params['limit'];
	if (!empty($_GET)){
			} else {
			$make = filter_var($search_chunks['make'], FILTER_SANITIZE_STRING);
			$model = filter_var($search_chunks['model'], FILTER_SANITIZE_STRING);
			$minPrice = filter_var($search_chunks['minPrice'], FILTER_VALIDATE_INT);
			$maxPrice = filter_var($search_chunks['maxPrice'], FILTER_VALIDATE_INT);
	if (!$details) {
			function getVehicles($make,$model,$minPrice,$maxPrice,$limit) {
				$vehicles = [];
				# Get vehicles
				$sql = 'SELECT c.category_name, a.title, CASE WHEN e.fielddef_id = 3 THEN d.value END AS price, CASE WHEN e.fielddef_id = 4 THEN d.value END AS photo FROM cms_module_lisevehicles_item a
				JOIN cms_module_lisevehicles_fieldval d ON a.item_id = d.item_id
				JOIN cms_module_lisevehicles_fielddef e ON d.fielddef_id = e.fielddef_id';
				if (empty($make) && empty($model) && empty($minPrice) && empty($maxPrice)) {
						$sql .= ' WHERE e.alias = "price"';
						if (!empty($limit)) {
							$sql .= ' LIMIT '.$limit.'';
				} else {
				    $sql .= ' WHERE ';
			        $sql .= 'c.category_name = '.$db->qstr($make).'';
							$sql .= ' AND e.alias = "price"';
			        $sql .= 'a.title = '.$db->qstr($model).'';
				    if (!empty($minPrice && empty($maxPrice))) {
							$sql .= 'e.alias = "price" AND d.value >= '.$db->qstr($minPrice).'';
				    if (!empty($maxPrice) && empty($minPrice)) {
							$sql .= 'e.alias = "price" AND d.value <= '.$db->qstr($maxPrice).'';
				    if (!empty($maxPrice) && !empty($minPrice)) {
							$sql .= 'e.alias = "price" AND d.value BETWEEN '.$db->qstr($minPrice).' AND '.$db->qstr($maxPrice).'';
				echo $sql;
				echo "<pre>";
				echo print_r($result);
				echo "</pre>";
					$vehicle->price   = $row['price'];
					$vehicle->photo   = $row['photo'];
				return $vehicles;
		$vehicles = getVehicles($make,$model,$minPrice,$maxPrice,$limit);
	} else {
		if (!function_exists('getVehicle')) {
			function getVehicle($make,$model) {
				# Get vehicles
			if (empty($make) || empty($model)) {
	  		echo "<div class=\"error\">";
				echo "Vehicle not found";
				echo "</div>";
			} else {
				$sql = 'SELECT c.category_name, a.title, MAX(CASE WHEN e.fielddef_id = 3 THEN d.value END) AS price, MAX(CASE WHEN e.fielddef_id = 4 THEN d.value END) AS photo, MAX(CASE WHEN e.fielddef_id = 5 THEN d.value END) AS description FROM cms_module_lisevehicles_item a
				    $sql .= ' WHERE ';
						$row = $result->fetchRow();
						$vehicle->description   = $row['description'];
				return $vehicle;
		$vehicle = getVehicle($make,$model);
		$smarty->assign('vehicle', $vehicle);
function smarty_cms_about_function_vehicles() {
	<h3>Version 1.0</h3>
<?php
The problem is it's not returning the photo. Bascially I want to pull mutliple values from the d.value coumn into it's own field in the results.
The table looks like this:
The sql output looks like this for the fields:
Code:
    [fields] => Array
            [category_name] => Audi
            [title] => A3 2.0 TDI
            [price] => 100
            [photo] =>
If I'm pulling a single result (second half of my code there) it works using MAX and the CASE. For multiple results the query fails. Any ideas?
Here is a suggestion, although I am not sure. It could be the fact that photo is not included in a JOIN statement. JOIN is a bit like venn diagrams, so you have to join where your data resides in order to display it. If you haven't joined anything related to photo, you won't get photo results.
You were sort of on the money there. There may be a much more efficient way of doing this, but to prevent duplicates and to pull the relevant rows into the correct objects, I ended up with this query:
PHP:
$sql = 'SELECT c.category_name, a.title, d.value as "price", d2.value as "photo", d3.value as "spec", d4.value as "deal"
JOIN cms_module_lisevehicles_fieldval d ON a.item_id = d.item_id AND d.fielddef_id = "3"
LEFT JOIN cms_module_lisevehicles_fieldval d2 ON a.item_id = d2.item_id AND d2.fielddef_id = "4"
LEFT JOIN cms_module_lisevehicles_fieldval d3 ON a.item_id = d3.item_id AND d3.fielddef_id = "6"
LEFT JOIN cms_module_lisevehicles_fieldval d4 ON a.item_id = d4.item_id AND d4.fielddef_id = "7"
Which spits out:
Code:
Array
    [0] => stdClass Object
            [make] => Audi
            [model] => A3
            [price] => 100
            [photo] => images/vehicles/A161000_medium.jpg
            [spec] => 2.0 TDI
            [deal] => 2 year deal
    [1] => stdClass Object
            [make] => BMW
            [model] => 335i
            [price] => 150
            [photo] => images/vehicles/2017-BMW-3-Series-Pictures.jpg
            [spec] => M Sport Coupe
            [deal] =>
    [2] => stdClass Object
            [make] => Audi
            [model] => A1
            [price] => 200
            [photo] => images/vehicles/2017-Audi-A1-concecpt.jpg
            [spec] => 1.6 TDI
    [3] => stdClass Object
            [make] => BMW
            [model] => 335i
            [price] => 150
            [deal] =>
