PHP issue with webpage
13 Jan 2007
Belfast,Northern Ireland
Basically the below all works fine, it is easily possible to login and do whatever I need. However the php entered causes everything below it not to be displayed....I do not know why. For example you have:
<div class="big-content-bottom">
</div> <!--end big content bottom-->
The image linked in the style sheet does not appear, nor does the footer. I dont quite understand as it is closed off correctly?
Code:
<div id="block_feature">
             <div class="big-content-top">
             <h4>ADMINISTRATOR ACCESS ONLY</h4>
             <h5>Please enter your login details below...</h5>
             </div> <!--end big content top-->
             <div class="big-content-middle">
             <?php
if (!isset($_SESSION['admin'])){
    echo '
<form action="admin_check.php" method="post" target="_self">
    Username:<input type="text" name="username" id="username"  />
	Password:<input type="password" name="password" id="password"  />
	' . $error_msg . '
   <input type="submit" name="button" id="button" value="Login" />
</form> ';
exit();
              </div> <!--end big content middle-->
             </div>  <!--end featured-->
