Hi Guys,
Im trying to loop through some code which builds up queries made and then prints out the data in their tables. I have a search function that the user can build up a query and then the results are presented in a table. I have a lot of tables which i want to loop through and print the results based on the query selected by the user. The table name are put into an array and i want to loop through and get the table names from the array. It is working for the first table which it prints out the results into a table but wont loop through for any of the others. Probably doing something stupid but here is my code:
As i said the code works fine for the first table in the array but wont loop through.
Could someone help me please??
Code:
$tables= array("table1","table2","table3");
//$arrlength=count($tables);
for($i=0; $i < count($tables); $i++)
$QBuild = "";
$QBuild .= "SELECT * FROM ($tables[$i]) WHERE($field)";
if($Date1 && $Date2 != NULL){
$QBuild .= "AND (Date BETWEEN '$Date1' AND '$Date2') ";
if($Initials != NULL){
$QBuild .= "AND (Initials LIKE '$Initials')" ;
if($PassFail != NULL){
$QBuild .= "AND (PassFail LIKE '$PassFail')" ;
if($circuit != NULL){
$QBuild .= "AND (circuit LIKE '$circuit')" ;
$result = mysql_query($QBuild);
// Prints the columns
echo "<table class='searchTable' border='1'; <tr>";
for($i = 0; $i < mysql_num_fields($result); $i++) {
$field_info = mysql_fetch_field($result, $i);
echo "<th>{$field_info->name}</th>"; }
// Print the data
while($row = mysql_fetch_row($result)) {
echo "<tr>";
foreach($row as $_column) {
echo "<td>{$_column}</td>"; }
echo "</tr>";
echo "</table>";
//This counts the number or results - and if there wasn't any it gives them a little message explaining that
$anymatches=mysql_num_rows($result);
if ($anymatches == 0)
echo "Sorry, but we can not find an entry to match your query<br><br>";
