PHP mail problem
14 Apr 2003
Deepest Yorkshire
Hi i'm having trouble running the php mail() function on my hosting. I was using a script I took off another site which worked correctly, when I put it on my site it doesn't fail, but it also doesn't send emails. 1&1 tech support monkeys sent me to a FAQ article with the following script in. I duly uploaded this and filled in my email address etc. However this doesn't work. After ringing them again they keep on repeating the same solution like some kind of stuck record, no matter how many times I tell them it doesn't work! grrr!
Do you think that their PHP might not be configured correctly or am I making some kind of fundamental error?
Code:
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Contact Us</title>
</head>
<body>
<form method="post" action="emailtest2.php">
  <table>
   <tr>
    <td>What is your name ?</td>
    <td><input type="text" name="name" /></td>
   </tr>
   <tr>
    <td>What is your e-mail address ?</td>
    <td><input type="text" name="email" /></td>
   </tr>
    <tr>
    <td> Comments:</td>
    <td><textarea name="data" cols=40 rows=6></textarea></td>
    </tr>
   <tr>
    <td colspan="2"><input type="submit" /></td>
   </tr>
  </table>
</form>
</body>
</html>
PHP:
$to = '[email protected]';
$subject = 'subject';
$message = 'From: ' . $_REQUEST['name'] . "\n\n" . $_REQUEST['data'];
$email = $_REQUEST['email'];
$headers = 'From: ' . $email . "\r\n" .
            'Reply-To: ' . $email . "\r\n" .
          'X-Mailer: PHP/' . phpversion();
mail ($to, $subject, $message, $headers);
Looks ok at a glance, although it is 1am...
Try just sending a simple email with the variables manually defined, just to check if it's maybe an error in what you're sending to the script.
also in your simple test email don't set the fourth param, the headers, just do the first three
and try to as many different email accounts (on differeing domains) as you have available
