PHP not creating sessions
8 Jul 2004
London
I was wondering if someone with a bit of know how of PHP could help me.
For some strange reason, I can not log into any php site hosted on my server which requires a cookie login. At first thought it was the script at fault so I re-installed but with the same results.
I then tried another script (a gallery) which requires user login but again, I could not get beyond the login page.
What happens after I press Submit is the login page simply refreshes. Nothing happens. I downloaded firebug to analyse what is being sent to the server and it seems the correct details are being sent.
This lead me to think it could be a issue with the way PHP is managing sessions (or not in this case).
I created a page called page1.php with the following code and placed it in the root www directory:
Code:
<?php //page1.php
session_start();
$_SESSION['name']="test";
header("location: page2.php");
In the same directory, I created a second php file with the following code and called the file page2.php:
Code:
<?php
session_start();
print_r($_SESSION);
I then browsed to http://domain.com/page1.php after clearing all my temp files, cookies etc.
Page2.php loads but it is blank.
The expected result would be for page2.php to display "test".
I have looked over my php.ini file and copied the session bit:
Code:
[Session]
; Handler used to store/retrieve data.
session.save_handler = file
; Argument passed to save_handler.  In the case of files, this is the path
; where data files are stored. Note: Windows users have to change this
; variable in order to use PHP's session functions.
; As of PHP 4.0.1, you can define the path as:
;     session.save_path = "N;/path"
; where N is an integer.  Instead of storing all the session files in
; /path, what this will do is use subdirectories N-levels deep, and
; store the session data in those directories.  This is useful if you
; or your OS have problems with lots of files in one directory, and is
; a more efficient layout for servers that handle lots of sessions.
; NOTE 1: PHP will not create this directory structure automatically.
;         You can use the script in the ext/session dir for that purpose.
; NOTE 2: See the section on garbage collection below if you choose to
;         use subdirectories for session storage
; The file storage module creates files using mode 600 by default.
; You can change that by using
;     session.save_path = "N;MODE;/path"
; where MODE is the octal representation of the mode. Note that this
; does not overwrite the process's umask.
session.save_path = "/var/lib/php5"
; Whether to use cookies.
session.use_cookies = 1
;session.cookie_secure =
; This option enables administrators to make their users invulnerable to
; attacks which involve passing session ids in URLs; defaults to 0.
; session.use_only_cookies = 1
; Name of the session (used as cookie name).
session.name = PHPSESSID
; Initialize session on request startup.
session.auto_start = 0
; Lifetime in seconds of cookie or, if 0, until browser is restarted.
session.cookie_lifetime = 0
; The path for which the cookie is valid.
session.cookie_path = /
; The domain for which the cookie is valid.
ini_set("session.cookie_domain","domain.com");
; Whether or not to add the httpOnly flag to the cookie, which makes it inaccessible to browser scripting languages such as JavaScript.
session.cookie_httponly =
; Handler used to serialize data.  php is the standard serializer of PHP.
session.serialize_handler = php
; Define the probability that the 'garbage collection' process is started
; on every session initialization.
; The probability is calculated by using gc_probability/gc_divisor,
; e.g. 1/100 means there is a 1% chance that the GC process starts
; on each request.
; This is disabled in the Debian packages, due to the strict permissions
; on /var/lib/php5.  Instead of setting this here, see the cronjob at
; /etc/cron.d/php5, which uses the session.gc_maxlifetime setting below
;session.gc_probability = 0
session.gc_divisor     = 100
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
session.gc_maxlifetime = 1440
; NOTE: If you are using the subdirectory option for storing session files
;       (see session.save_path above), then garbage collection does *not*
;       happen automatically.  You will need to do your own garbage
;       collection through a shell script, cron entry, or some other method.
;       For example, the following script would is the equivalent of
;       setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
;          cd /path/to/sessions; find -cmin +24 | xargs rm
; PHP 4.2 and less have an undocumented feature/bug that allows you to
; to initialize a session variable in the global scope, albeit register_globals
; is disabled.  PHP 4.3 and later will warn you, if this feature is used.
; You can disable the feature and the warning separately. At this time,
; the warning is only displayed, if bug_compat_42 is enabled.
session.bug_compat_42 = 1
session.bug_compat_warn = 1
; Check HTTP Referer to invalidate externally stored URLs containing ids.
; HTTP_REFERER has to contain this substring for the session to be
; considered as valid.
session.referer_check =
; How many bytes to read from the file.
session.entropy_length = 0
; Specified here to create the session id.
session.entropy_file =
;session.entropy_length = 16
;session.entropy_file = /dev/urandom
; Set to {nocache,private,public,} to determine HTTP caching aspects
; or leave this empty to avoid sending anti-caching headers.
session.cache_limiter = nocache
; Document expires after n minutes.
session.cache_expire = 180
; trans sid support is disabled by default.
; Use of trans sid may risk your users security.
; Use this option with caution.
; - User may send URL contains active session ID
;   to other person via. email/irc/etc.
; - URL that contains active session ID may be stored
;   in publically accessible computer.
; - User may access your site with the same session ID
;   always using URL stored in browser's history or bookmarks.
session.use_trans_sid = 0
; Select a hash function
; 0: MD5   (128 bits)
; 1: SHA-1 (160 bits)
session.hash_function = 0
; Define how many bits are stored in each character when converting
; the binary hash data to something readable.
; 4 bits: 0-9, a-f
; 5 bits: 0-9, a-v
; 6 bits: 0-9, a-z, A-Z, "-", ","
session.hash_bits_per_character = 4
I also ran phpinfo to confirm the save location of the session and it matches with full 777 privileges to the webserver user account.
I cant figure out for the life of me why PHP is not creating any sessions :confused:
Server is running:
Apache v2.2.8
PHP 5.2.4-2
MySQL v5.0.51
Assuming my domain is domain.com and I am running the script on the root folder.
