- 4 Mar 2010
Hi guys having a bit of trouble with a couple of classes...
I am getting no errors caught nor a confirmation to say a connection was successful using PDO called in a class and it's becoming a little annoying. The connection details are being called from a static class; also no errors , it seems.
It just seems to fall asleep inside the classes as the </body></html> is not being output.
If I may I will do a code dump of the files in question, any help would be awesome!
Index.php
display_names.php
db_details.php
Index.php
PHP:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Display Names</title>
</head>
<body>
<?php
error_reporting(E_ALL);
require_once($_SERVER['DOCUMENT_ROOT']."/php/classes/display_names.php");
$display = new display_names(db_details::admin_user, db_details::admin_pass, db_details::hostname);
$display->connect();
</body>
</html>
display_names.php
PHP:
<?php
* This class is used for getting usernames from the table 'oop'
* db_details is required as it contains the user and pass needed to connect.
* @author Lukie
require_once($_SERVER['DOCUMENT_ROOT']."/php/classes/db_details.php");
class display_names
public $user;
public $pass;
public $hostname;
public function __construct($user,$pass,$host)
$this->user = $user;
$this->pass = $pass;
$this->hostname = $host;
public function connect()
try
$db = new PDO("mysql:host=$this->hostname;dbname=mysql", $this->user , $this->pass );
echo 'sucess';
catch(PDOException $e)
echo $e->getMessage();
db_details.php
PHP:
<?php
* This is a static class containing all the connection
* usernames and passwords needed for the database.
* admin has open access to all tables while general has no writeible permissions and only access to articles table.
* @author Lukie
class db_details
static public $admin_user = 'root';
static public $admin_pass = '';
static public $general_user = '';
static public $general_pass = '';
static public $hostname = 'localhost';
It's only because I'm so lovable!
