PHP & PDO SQL Query - Help I'm Stuck!
17 Aug 2012
Tamworth, UK
Hi All,
Hit a bit of a snag with some University work I'm completing, we need to design a animal adoption website with various functionality for both a staff member and a normal user.
So far I have setup the index page, ability to login, register etc.
One of the things we need to setup is the staff member needs to be able to see which animals are available for adoption and who owns them. When a staff member uploads a new animal it automatically updates the "owns" table with the userid of the member of staff and animal id of the new animal (auto-increments).
I have a PHP page that pulls the information into a table which is working perfectly fine, it runs a query to select * from the animal table where available = YES, however it's missing the owner details as that needs a JOIN to the user, animal and owns tables.
My database looks like this:
4 Tables - user, animal, owns, adoptionrequest (irrelevant atm)
user = userid, username, staff, password
animal = animalid, name, dateofbirth, description, type, photo, available
owns = animalid, userid
Using this SQL I can select my user from the user table successfully joining owns and animal.
Code:
SELECT username FROM user
INNER JOIN owns
ON user.userid = owns.userid
INNER JOIN animal
ON animal.animalid = owns.animalid
where animal.name = '15';
However in PHP it throws me an error to do with there being no query buffer which I assume is because of how it's using a while loop to populate the table and then I'm trying to run another SQL query to populate just the owner column of the table on the webpage?
Here's my code for the page which will explain better with what I'm trying to achieve:
Code:
<?php
	session_start();
	if (!isset($_SESSION['username']) and ($_SESSION['usertype']!=1)){
		header("Location: index.php");
	$husername=$_SESSION['username'];
    // Database Connection
	require_once ('connectdb.php');
	$getinfo="SELECT * FROM  animal WHERE available = 'Yes'";
	$rows =  $db->query($getinfo);
 	if ( $rows && $rows->rowCount()> 0) {
		include("header.php")
    <!-- Start HTML Form -->
    <!-- Create Animal table -->
<table border="1px" cellpadding="5px">
<tr>
			<th align='left'><b>Photograph</b></th>
			<th align='left'><b>ID</b></th>
			<th align='left'><b>Name</b></th>
			<th align='left'><b>DOB</b></th>
			<th align='left'><b>Description</b></th>
            <th align='left'><b>Type</b></th>
			<th align='left'><b>Available</b></th>
            <th align='left'><b>Owner</b></th>
			<th align='left'><b>Click to Edit</b></th>
</tr>
    <!-- Use PHP to grab information from the database, while loop -->
    <?php while ($row = $rows->fetch())	{ ?>
    <!-- Trying to populate the owner column of the table -->
    <?php $getanimalid = $row['animalid'] ?>
    <?php $owner = $db->exec("SELECT username FROM user INNER JOIN owns ON user.userid = owns.userid INNER JOIN animal ON animal.animalid = owns.animalid where owns.animalid = '$getanimalid'");
<tr>
    <!-- Display Image & Details of animal stored in DB -->
        <td><?php echo '<img src="' . $row['photo'] . '" />'; ?> </td>
        <td><?php echo $row['animalid'] ?> </td>
        <td><?php echo $row['name'] ?> </td>
		<td><?php echo $row['dateofbirth'] ?> </td>
        <td><?php echo $row['description'] ?> </td>
        <td><?php echo $row['type'] ?> </td>
        <td><?php echo $row['available'] ?> </td>
        <td><?php echo $owner ?> </td>
    <!-- Edit Button & Values are brought into the page -->
        <td><a href = "updateanimal.php?animalid=<?= $row['animalid']?>&name= <?= $row['name']?>&dateofbirth='<?= $row['dateofbirth']?>'&available=<?= $row['available']?>">Edit</a></td>
			</tr>
		<?php
		echo  '</table>';
	else {
		echo  "<p>No animals to display.</p>\n";
<html>
    <form action ="staff.php" method="post">
    <p><input type="submit" name="Register" value ="Go Back" /></p>
    </form>
</html>
<?php
    include ('footer.php')
I'm very far from a decent PHP developer and a lot of this is loosely learned so expect it to be incorrectly used.
Here's how the webpage looks when running the above code:
Here's with that code commented out and "" used instead.
Hope I've explained myself well enough, but any guidance would be appreciated.
That doesn't really help me as I've already looked through the error message and they mention using closeCursor, but I can't use that as I need the result from running query as that has the $row['animalid'] I want to use.
I know the issue lies with how I'm trying to run the INNER JOIN in the middle of the while loop as I'm trying to use the animal id it pulls from the fetch, but I don't know another way of getting the matching animal id to put into the select statement.
Confused.
Thought, if I create a view of the JOIN and then use that in the PHP page it will pull in all the information I need, meaning I only need a simple SQL statement?
Plus a view will remain up to date.
I think this will work?!
EDIT: Worked beautifully, and I can do the same for the user view of the table.
You can get all the information you want in a single query just by changing the where clause in your main query to 'where animal.available = yes'. Then just add the columns from the animal table that you want to see to your 'select' part.
This was my revelation in the end!
Can't believe it took me so long to think of changing the original query, so I've now created 3 views, one for the staff members, one for the user (minus some data) and another for the adoption requests when a user has selected to adopt a pet.
Slowly coming together now! :D
