php preg_match
19 Jul 2006
I have the following code that checks to see that the email is correct.
How do i alter the phone one to check that it contains at least 9 numbers?
PHP:
//Check to make sure sure that a valid email address is submitted
		if(trim($_POST['email']) === '')  {
			$hasError = true;
		} else if (!preg_match('^[a-zA-Z0-9_.-]+@[a-zA-Z0-9-]+.[a-zA-Z0-9-.]+$^', trim($_POST['email']))) {
			$hasError = true;
			$errorMessage = "Please enter a valid email address!";
		} else {
			$email = trim($_POST['email']);
		//phone
		if(isset($_POST['phone'])) $phone = trim($_POST['phone']);
TIA
PHP:
	if (trim($_POST['phone'] === ''))
		$hasError = true;
	else if (!preg_match('(\d{9})', trim($_POST['phone'])))
				$haserror = true;
				$errorMessage = "Your phone number must have 9 digits";
			else
	print $errorMessage.'<br>';  // Dont need this line
I just tried this out and it worked for me. Hope that helps.
Just checked that site which is good but im now unsure of the {} on the site is says
{9} means exactly 9
Now in the code above {9} seams to work with 9 or above?
{9} means exactly 9
Hi Hargi,
Yes, you are right, the {9} picks up with 9 or above. :eek:
So I replaced it with (\A\d{9}\Z) That seems to work. :)
