php, problem echo'ing results from mysql table
11 Oct 2008
I'm fairly new to php/mysql and I've been following the w3 tutorials.
i am using this code to connect to my database:
PHP:
<?php
$con = mysql_connect("localhost","peter","abc123");
if (!$con)
  die('Could not connect: ' . mysql_error());
mysql_select_db("my_db", $con);
$result = mysql_query("SELECT * FROM Persons");
while($row = mysql_fetch_array($result))
  echo $row['FirstName'] . " " . $row['LastName'];
  echo "<br />";
mysql_close($con);
Is there anyway to echo the results without having to use this whole chunk of code every time?. I tried the following with no luck.
PHP:
<?php
echo .$row['FirstName'];
Does anyone know what I'm doing wrong?
You could create a function that gets rows from a database.
Code:
GetFullName() {
    //the code
and include it on the pages necessary. Call the data by simply running the function.
Or go a step back and create a function that simply runs the query... so it would look like
Code:
GetResults($query) {
  // connect
  $r = mysql_query($query);
  return  $r;
  //close con
then include that file where needed and
Code:
$data = GetResults("SELECT first_name, last_name FROM persons");
then just
Code:
<?php foreach($data as $value): ?>
    <p><?php echo $value[first_name]; ?> <?php echo $value[last_name]; ?></p>
<?php endforeach;  ?>
That's hard for me to say really mate as I've always used the PDO. Well for a start it's object based and objects are nice :) I would imagine it provides better protection against SQL injection over the mysql functions. It's dead simple to use.
Code:
<?php
	$host = "localhost";
	$databaseName = "databaseName";
	$username = "username";
	$password = "password";
	try{
		$PDO = new PDO("mysql:host=".$host.";dbname=".$databaseName,
						$username, $password);
		$sth = $PDO->prepare ("SELECT * FROM price WHERE price = :price");
		$sth->execute(array(":price"=>$price));
		$products = $sth->fetchAll(); //Array of rows
		foreach($products as $product){
			echo $product[0]; //Echo product's ID
			echo $product[1]; //Echo product's name
		$PDO = null; //Close connection
	catch(PDOException $e)
		//Deall with error
If you checked out the code before the edit please note the addition of the try-catch! Also I said that execute() will clean the string. Not sure why I remembered it operating like that (sorry, been a while!) so you need to ensure that any input from the user is clean. You probably already knew that but thought I'd mention it in-case.
Ok, I think i have a basic understanding of it now, apart from I cant seem to close the connection without getting errors.
I have a connection.php file with the following code:
PHP:
<?php
/*** mysql hostname ***/
$hostname = 'localhost';
/*** mysql username ***/
$username = 'username';
/*** mysql password ***/
$password = 'password';
try {
    $dbh = new PDO("mysql:host=$hostname;dbname=dbname", $username, $password);
    /*** echo a message saying we have connected ***/
    echo 'Connected to database <br /><br />';
    echo $e->getMessage();
and i have a settings.php file that runs my query:
PHP:
<?php
    /*** The SQL SELECT statement ***/
    $sql = "SELECT * FROM website_test WHERE id='1'";
    foreach ($dbh->query($sql) as $row)
        $id = $row['id'];
	$name = $row['name'];
now that all works fine when I echo my variables, but I cant seem to place the code to close the connection in any part without errors :( Any ideas where I can place it?
Cheers
You should really be using a PDO to interact with databases in PHP.
My 2 pennies - Depends on the situation and application being designed as there are pros and cons for both PDO and mysql/mysqli ie: if performance is a big issue then mysqli offer marginally better performance than PDO, similary there are a few advanced functions PDO doesn't support that Mysqli does.
I'm not sure I entirely understand your problem. I assume you're using require() on connection.php within settings.php? If you want your database details stored within one location then I'd do the following:
Code:
<?php
Class DBConnection
     * Database connection information
    const HOST = "localhost";
    const DATABASENAME = "dbname";
    const USERNAME = "username";
    const PASSWORD = "password";
     * Represents a connection to a database
     * @var PDO
    private $dbh;
     * Construct an instance of DBConnection.
     * This will consequently invoke a connection to
     * the database
    public function __construct()
        connect();
     * Connect to the database
    public function connect()
        try{
            $this->dbh = new PDO(
                    "mysql:host=".self::HOST.";dbname=".self::DATABASENAME,
                    self::USERNAME, self::PASSWORD);
        catch(PDOException $e){
            echo "Connection failed: ".$e->getMessage();
     * Disconnect from the database
    public function disconnect()
        $this->dbh = null;
     * Get the PDO to carry out queries
     * @return PDO
    public function getPDO()
        return $this->dbh;
Not tested! Within settings.php you can then just make an instance of DBConnection and invoke disconnect when you're done.
Let me know if I've misunderstood the problem and if not , let me know if that does what you need.
Oh yes, you'll need to include the .php file that DBConnection is stored within so I find it helpful to define the following function in any file that might make an instance of something:
Code:
function __autoload($className){include "classes/".$className . '.php';}
If you try to make an instance of a class that it can't "see", this will be the last port of call before error messages. Pretty handy if you're using multiple classes :)
Fair points. Whatever fits the bill I guess :)
