PHP problem
29 May 2006
Hi all,
Got a problem with some PHP that I can't figure out. I'm sure it's staring me in the face but I'm not seeing it.
I won't post all the code but the jist is this:
PHP:
Class MyClass {
    public $Variable;
    public function A() {
        if(some conditions) {
            // code here etc
            // end result
            $this->Variable = $min($somearray);
        // more code here unrelated to $this->Variable;
    public function B() {
        // loads of code here, none of it touching $this->Variable
        echo $this->Variable;
    public function C() {
        $this->A();
        $this->B();
// Go to use the Class
$Obj = new MyClass();
$Obj->C(); // $this->Variable not echo'd
// but if I do this !!
echo $Obj->Variable; // I get the value I want !
For some reason, I can access and return the value of $variable through $Obj but when I use $this->Variable within a method of the class, its not returning a value.
I've checked for typos can't see anything wrong. No synxtax highlighting errors anywhere.
I can't see why it wouldn't work. All the methods are public and so is the variable. :confused:
Mmm ok. It works now that I've scrapped B and put the code into A. Thanks. How come it didn't work in the first place? I thought a public variable declared like that could be accessed by any method in the class?
I've set public variables before e.g.
$Obj = new Class();
$Obj->DataVar = array(1,2,3);
$Obj->MethodWhichUsesDataVar(); // some rubbish to do with array is returned.
I've got a solution (Thanks :D) but don't understand what was wrong in the first place :confused:
It was running the code but not actually being told to return anything. Obviously a class doesn't always have to return something, but in your case you wanted data back. The other methods had nothing to access because nothing was stored.
