php question - Arrays with =>...
4 Jul 2004
aberdeen
Hello,
I have an array...
$example = array(
"parta" => "partb",
"parta1" => "partb1",
"parta2" => "partb2");
And want to do:
while (certaincondtion = true) {
if ( $example[$i] == $foo) {
echo $bar;
$i++;
I want the "$example[$i] " to look for "parta" (ie before the =>), and then i want to echo $bar, and set bar at the "partb" (ie after the =>)
How do i do this.....
cheers
This should do the trick, if I understand you correctly:
Code:
foreach ($example as $key => $value)
    if (!$certainCondition)
        break;
    echo $value;
