php question please!
16 Oct 2007
UK
Hello all,
I've got a bit of php that counts the total number of records in my database, and displays it in "** jobs from ** companies"
Code:
error_reporting(0);
function getTotalJobCount(){
  include("jobs_config.php");
	mysql_connect($DBHost,$DBUser,$DBPass);
	mysql_select_db($DBName);
	$strQuery="
	SELECT count(".$DBprefix."ext_postings.id) as totaljobs, count( DISTINCT ".$DBprefix."ext_postings.employer) as totalemployers FROM ".$DBprefix."ext_employers , ".$DBprefix."ext_postings
	WHERE
	".$DBprefix."ext_postings.employer =  ".$DBprefix."ext_employers.username
	AND expires>".time()." AND ".$DBprefix."ext_postings.active='YES'";
	$result=mysql_query($strQuery);
	$row=mysql_fetch_assoc($result);
	return $row['totaljobs']." jobs from  ".$row['totalemployers']." companies";
echo getTotalJobCount();
That bit works fine
I also have another script that displays info (such as IP address) as an image
Code:
<?php
Header ("Content-type: image/png");
$img_handle = imageCreateFromPNG("images/bannerboy.png");
$color = ImageColorAllocate ($img_handle, 100, 100, 100);
$ip = $_SERVER['REMOTE_ADDR'];
ImageString ($img_handle, 3, 10, 9, "Your IP: $ip", $color);
ImagePng ($img_handle);
ImageDestroy ($img_handle);
This also works fine.
But i'm trying to combine the two! And having some mixed results....
Basically, i want to have "** jobs from ** companies" on an image.
Any ideas?
Thank you!
i can't see why it's not working??
here i've just removed the function - no need for it as the code isn't being re-used....
PHP:
<?php
$strQuery="
	WHERE
$image_text = $row['totaljobs']." jobs from  ".$row['totalemployers']." companies";
ImageString ($img_handle, 3, 10, 9, $image_text, $color);
