PHP Script - For Opening a Document
18 Oct 2002
Sandwich, Kent
I'm looking for a script where I can pass a file name like
xxxxxx.co.uk/opener.php?testdocument.doc
and have it open the relevant document, and count the number of times its been opened.
I'm sure I could write something, but I just wondered if a script was was already around to do this.
Be very careful with a script like that; it's a (very big) potential security hole if not done properly. Make sure that users can only access the files that you want them to be able to access, so they can't do something like this (assuming your files are kept in a subdirectory of the webroot):
Code:
http://insecurewebsite.co.uk/opener.php?file=../index.php
The most secure way of doing it would simply be to keep records of files in a database, and give them each an id, so you'd access them like so:
Code:
http://securewebsite.co.uk/opener.php?fileid=1
Code:
Code:
Thanks for the info. I see what you mean. Lucky I didn't put that live yet!
Ok, I've made a modification to try and prevent that. Fancy trying it out for me.. See if you think it's still vulnerable.
He's just doing a meta refresh to it, the only problem will be with XSS. There won't even be any problems if he does a 301 redirect from the script :)
Nope, it's done via PHP. Try disabling meta redirects and going to http://www.kentprobation.org/downloader/index.php?id=testfile.doc :)
Bug One said:
I've sent you the code.
Yep, I've got it. I just meant it would be more efficient to talk about it over MSN than on the boards if you don't want to post the source on the boards :)
