PHP string function problem
24 Aug 2003
Derbyshire
I have a series of (different) strings, I wish to perform an insert/replace (replace \n (newline characters with some text) on each of the strings but only between certain points/indices in them.
I'm currently carrying out a horrible mess of searching, sub string copying, preg'ing and reinsterting.
Can anyone suggest a better way - I've been trying to find a single function to do it - basically a "preg_replace" but only between certain points.
Split it, then replace text only on the indice you want, then implode:
Code:
<?php
$parts = preg_split('/pattern/', $string); // or can use explode
$parts[1] = str_replace("\n", '', $parts[1]);
$string = implode('', $parts);
Cheers :)
I got into work this morning to find they changed the spec of what they wanted, :rolleyes: in the end I did something similar to what you suggested, just a little less elegantly due to some extra string trimming and extra concatenation I had to carry out.
thanks again
Dj_Jestar said:
the indice you want
Index*
