PHP syntax error help
7 Jan 2007
Sussex, UK
PHP:
foreach ($variable1 as $element) {
	if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d=="Tue") {
        mysql_query("INSERT INTO table1
					(idproducts, info1, info2, info3, info4, info5, info6, fullinfo1, drawndate, drawnyear) VALUES('9', '$variable1[0]', '$variable1[1]', '$variable1[2]', '$variable1[3]', '$variable1[4]', '$variable1[5]', '$variable1[6]', NOW(), NOW())")
or die(mysql_error());
mysql_query("UPDATE table2 SET dates = DATE_ADD(DATE_ADD(DATE(NOW() + INTERVAL 2 DAY), INTERVAL 19 HOUR), INTERVAL 00 MINUTE)
			WHERE idsomething = '9'")
		break 1;
	} if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d=="Thu") {
		break 1;
	} if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d=="Sat") {
mysql_query("UPDATE table2 SET dates = DATE_ADD(DATE_ADD(DATE(NOW() + INTERVAL 3 DAY), INTERVAL 19 HOUR), INTERVAL 00 MINUTE)
		break 1;
		} else {
        echo "'{$element}' is NOT numeric or results same as last week, or It isn't Thursday", PHP_EOL;
mysql_close();
Can anyone spot the syntax error?
PHP:
Does your editor highlight the opposite bracket when you select one? there's nothing in that foreach loop.
PHP:
	if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d == "Tue") {
		break 1;
			if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d == "Thu") {
				break 1;
				if ($variable1 != $LastWeeksVariable && is_numeric($element) && $d == "Sat") {
					break 1;
				} else {
mysql_close();
Overall the code is quite ... what are you trying to achieve with this?
Try some better structure:
PHP:
	if($variable1 != $LastWeeksVariable && isset($d) && $d != '')
		switch($d)
			case 'Tue':
				/* Setup Values */
				break;
			case 'Thu'
				/* Setup Values */
				break;
			case 'Sat':
				/*Setup Values */
				break;
			default:
				/* Setup values */
		if($values) { /* Check all values are setup correctly */
			/* Do Query */
		} else {
			/* Uh oh! You dun goofed */
The goal is to remove redundant data and checks.
OK I now have this, which is much easier to follow. However, it is inserting 7 lines into my db, because of the loop. How do I make it only do a first pass then stop?
It is entering the same line 7 times into my db now.
PHP:
 if($variable1 != $variable2 && is_numeric($element) && isset($d) && $d != '')
        switch($d)
            case 'Tue':
						(idproducts, info1, info2, info3, info4, info5, info6, totalinfo1, drawndate, drawnyear) VALUES('9', '$variable1[0]', '$variable1[1]', '$variable1[2]', '$variable1[3]', '$variable1[4]', '$variable1[5]', '$variable1[6]', NOW(), NOW())")
						WHERE idtable2 = '9'")
                break;
            case 'Thu':
                break;
            case 'Sat':
                break;
            default:
						echo "error";
PHP:
$inserted = false;
 if($inserted) { continue; }
        switch($d)
            case 'Tue':
                        $inserted = true;
                break;
            case 'Thu':
                        $inserted = true;
                break;
            case 'Sat':
                        $inserted = true;
                break;
            default:
                        echo "error";
Though I am fairly sure there's a better method of doing this. When do you call this action?
PHP:
        switch($d)
            case 'Tue':
                break;
            case 'Thu':
                break;
            case 'Sat':
                break;
            default:
						echo "error";
Your values should be from element[] not variable1[], otherwise your code makes no sense. Another tip is use PDO, and prepared statements, as opposed to mysql_query, etc.
