PHP Text Replacement
13 Nov 2003
Manchester
Hi All
Working on a script that imports a large amount of data from a csv file into a database.
However some of the lines in the CSV contain nasty characters which mySQL doesn't like, apostraphes for example.
Can someone recommend a piece of code that can be used to replace these.
I have had a look at a lot of the examples online, however I need to be able to specify multiple rules, ie replace ' with a ft or & with and.
I dont want to use too many loops etc as the data file will have almost 80000 lines when the site goes live and I don't want it to take weeks. At the moment my test file has 7000 lines and it takes 3-4 seconds to process that.
Any advice is greatly appreciated.
Thanks
Aaron
PS - in case it helps, here is the script so far
Code:
$file = array();
foreach(file('****.csv') as $line)
    $file[] = explode(',', $line);
foreach($file as $data) {
mysql_select_db($database_wp_master, $wp_master);
$insert*** = "INSERT INTO ***_temp VALUES('$data[12]','$data[13]','$data[11]','$data[15]','$data[9]','$data[3]','$data[20]','$data[21]')";
mysql_query($insert***, $wp_master) or die(mysql_error());
echo 'Data Imported<br/><br/>';
Thanks Jestar
Im not too sure whats this sprintf stuff is and how it works, how would I rewrite my query to use it?
Would it be like this?
Code:
$query = sprintf("INSERT INTO **_temp VALUES('%s','%s','%s','%s','%s','%s','%s','%s'",
mysql_real_escape_string($data[12]),
mysql_real_escape_string($data[13]),
mysql_real_escape_string($data[11]),
mysql_real_escape_string($data[15]),
mysql_real_escape_string($data[9]),
mysql_real_escape_string($data[3]),
mysql_real_escape_string($data[20]),
mysql_real_escape_string($data[21]));
mysql_query($query, $wp_master) or die(mysql_error());
Only escape input as you're using it in a query to avoid having slashes where there shouldn't be slashes—the sprintf method is a good one to help you with this, since if you do it for all queries you can't possibly pass unescaped data by accident :)
Make sure you're handling Magic Quotes too :)
Would it be a good idea to use something else to remove all the slashes? Or should I remove the characters that are causing the slashes before I run the query, so that way I can cut out the slashes that occur frequently and still be safer from injection attacks etc.
The data all comes from a distributors CSV product list, so there is no user input as such - although it's best not too leave it to chance
