PhpBB Forum Problem
11 Apr 2003
Notts
Hi All, Got my forum set up.... No problem, Installed quick reply mod no problem, Had it running for about 3 months No problem, then about a week ago I and others on my forum became unable to quote anything....
Or to the point, If i hit quote it will go
nameofposter said:
and be all broken, But if I type out
It works, I have no idea why it is doing this, nor how to fix it so hitting the Quote button does what it should.... Here are my forums:
http://forums.jcb33.co.uk/
And here is an example of the problem Quoting:
http://www.jcb33.co.uk/forum/viewtopic.php?t=67
If you havent changed anything and it has been running fine for the past 3 months then the first thing to try is a database repair.
Dan
Dan
Remember to backup the database 1st. But then again, you should be doing that anyway :p
