I'm having a problem with a script that I downloaded which is no longer supported by the author. When I log in to my file manager, everything loads correctly and then the file manager frame disappears. i believe this is because IE7 doesnt allow you to load pages with javascript errors. I would really appreciate it if someone could take a look just incase it is an easy fix.
Here is the error returned by IE7:
Line 872
Char 3
Error Invalid argument
Code 0
URL: http://hotorwot.com/phpxplorer/syst...ory_simple&sPath=&start=true&bAllowSelection=
Demo: http://hotorwot.com/phpxplorer/
login root/root
Code: http://www.phpexplorer.org/
Line 872
Char 3
Code 0
login root/root
