PhsyX Card...
well if he gave it to you than might as well make use of it :P if you can fit it on the mobo
I wonder if those physics cards can run on Nvida physics X drivers if they can it would be ideal for phyiscsX games
They can ;)
Well the games have to be Physx enabled. Mirros Edge for example is, whereas CSS isn't. It will only be woth it if the games you are going to be playing as Physx based. But as you got it for free i would just stick it in if you have room on the motherboard.
there is the use for it :P
I ve been tring to find one for ages not luck at all oh well won't fit between two HD4890 :|
