Hi guys,
I have an ESXI server with two physical drives installed. The first one holds all my VM's and associated datastores for those. I want to use the second drive for additional data storage as and when required.
Annoyingly I had this working previously when I set it up with the VMware thick client but I can't work out how to do it on the v6.x web client.
Do I need to create a datastore on the 2nd HDD? It will used be used only for raw storage and I'll share it out over the network for other VM's to be able to read/write to when required, but primarily it will be one VM requiring usage.
Any advice would be greatly appreciated, I'm running ESXi v6.7
I managed to complete the RDM action, however a new problem I am experiencing is that the storage drive is only presenting to Windows as a 2TB drive (1.5 TB usage storage), despite being a 6TB HDD. I'm still researching this at the moment, there appears to be a previously known issue with older versions of ESXI where there was a 2TB limitation on VMDK files, however this should have been resolved in later versions.
