- 27 Apr 2004
I'm doing A2 physics this year and have got a bit of a problem with the explanation of Young's Double slits experiment we were given.
I understand and appreciate that fringe interference patterns are created.
I also understand that this only happens with coherent sources, which have been defined to us as sources that have constant phase difference.
The problem I have is that we've been told that for constructive interference to occur, the path difference must be a whole number of wavelengths, and for destructive interference, the path difference a whole number of wavelengths plus a half.
I appreciate that this is true if the sources are in phase, but fail to see how this is true if the sources are out of phase, even if they do have constant phase difference.
Diagram:
The point that I dispute is that we have been told the path difference is always a whole number of wavelengths for constructive interference to occur. I disagree with this and say it is only true for sources in phase, as in my above example the path difference would have to be 0.25 wavelengths (i.e distance from S2 should be 10.75 wavelengths) for constructive interference to occur at point P.
Hopefully I've been able to explain my point in a comprehensible way, now:
Have I been really stupid and missed something obvious or is my thinking correct?
Thanks for reading
Diagram:
Thanks for reading
