I have a 5970 and looking to add a physics card to the equation.
So the Q is whats the best one to go for?
Don't bother, not enough games to warrant the hassle
My 9600gt is fine though, average 30 fps in mafia 2 with physx high, AA and everything max 1920x1200, batman AA plays smooth as silk physx on max
Physx described in one word....crap.
Looks great in Batman though. And Dark Void. And Metro 2033. And Mafia 2.
lol Dont say that. Was just starting to give up on the idea.
the API itself is pretty great, so far whats been crap is the implementation of it even by nVidias dev support teams :S as you rightly point out above the scripted "physics" used for most of the effects in mafia 2 are just laughable.I wish people would diferentiate between the API and developers useage of itthe API itself is pretty great, so far whats been crap is the implementation of it even by nVidias dev support teams :S as you rightly point out above the scripted "physics" used for most of the effects in mafia 2 are just laughable.
Na wasnt going to go to the Green side. It was just to remove some load from the 59
