Physics Help
I put that in my mid term exam and was marked wrong but I can't think what else it should be, so I'm starting to think I should have got that right!
It means that in SI units, the units of power are kilogram metres squared over seconds cubed.
Just for the record, the correct answer to the OP can be found in the second post, so you can safely ignore everything else in this thread as I predict that it will soon be filled with 'helpful' people coming in and giving the wrong answer and then an argument over who's right will ensue. ;)
PhilthyPhil said:
kgm^2s^-3
Yep that's it. I guess base units must stand for SI units now then. I'd probably have said Watts too though, and I'm studying Physics at university :o
The SI is just a unit system, so saying SI units is slightly ambiguous. Generally you would refer to ‘base units’ or ‘SI base units’ and ‘derived units’, Watts being a derived unit.
power = rate in change of energy = energy/time = joules/seconds
workdone(measured in joules) = force x distance
energy = ma x d = kgm(s^-2) x m=kg(m^2)(s^-2) = joules
so joules / seconds = kg(m^2)(s^-2) / s = kg(m^2)s(^-3)
Ya think? ;)
