Physx being a POS.
20 Oct 2010
Scotland, My home.
When i upgraded to my 570, i did an absolute clean reinstall if nvidia drivers. I cant play metro 2033 because of a physx problem. So i decided to reinstall drivers. Not working.
On the nividia installer it says physx failed to install. So what i did after that is i went into the windows remove programs and saw there was no nividia physx installed.
After that i did a bit of research. Lots of people say download a later version of physx and install the older version then upgrade again. Well i downloaded it but i cant install it. It says there is a newer version and then aborts the installation.
I downloaded driver sweeper and it cant uninstall physx because its already uninstalled.
I have no clue what to do now. Can anyone point me in the right direction?
I take it you're installing the latest driver? When you ran the Nvidia installer did you click on "perform clean install"?
